- Jan 10, 2012
caddi daddi| 8086k| water| 59.343
man, lots of avx.
In w10, search for cmd. When you see the icon, right click and run as admin. Then paste the command to enable. In other words, the command line app is what you need to run as admin.
lol, this!
what command?
Edit: your status is ok though???
Edit2: you also ran the wrong one.
Its in the program under options.can someone post the command line code to enable HPET in windows 8/10 please.
@Johan45 This bench loves cores, can you show us a Thread ripper Run please (stock ok)
To change it in Windows 10. You must run the command that is in the program. The problem is that the program does not have admin rights and can't change anything. You must open a CMD window with admin rights. Then you can run "bcdedit /set useplatformclock true".
Thanks for the info Mysticial and welcome!
Not at all surprised to hear about Hwbot using something different in comps... I'm not sure they know if they are coming and going at times.
