- Dec 15, 2011
What does Memtest86 say?
I don't know if this is an issue on your mobo, but on some SuperMicro boards, powering the fans, especially a lot of fans or fans with a large current draw (big), makes the board run very slow and jerky.
If you have a lot of fans, or big fans, use the psu to power them, instead of the board.
So you're running it with two cpu's atm?
And you'll laugh at this, but I'm very careful to avoid walking near the system, while it's burning. My opinion is, any vibration is a bad one when you're burning a CD. Naturally, I don't fold while I'm d/l'ing or burning a Linux file, either.
I tried 2008 r2 for about 2 minutes.
It wouldn't run and I assume it needed to be run as a service of something so I wiped it and installed Ubuntu and haven't looked back.
I believe he wants to use Windows - specifically this particular version of Windows.
Dimension (W / H / D) 344 x 704 x 664 mm / 13.5 x 27.7 x 26.1 inch
Weight 22kg / 48.5 lb
M/B Type Micro-ATX, ATX, E-ATX, XL-ATX, SSI CEB, SSI EEB
