jae87 said:I wonder if you guys missed this article?
http://www.overclockers.com/tips1211/
Because it's more or less the same concept. Hot water moves up, replaced by cooler water, creating movement in the loop. I just find it strange that no one discussed that informative article.
Also, how does the calm-sv radiator work? Looks odd to me, both incoming and outgoing lines are on the same side (and in close proximity to each other). I wonder if there's some water routing inside that seperates the incoming and outgoing lines?
*edit:
ok, i guess ls7corvete's writeup wasnt all that informative, but shortly after reading it a week or two ago i looked up posts on pumpless watercooling. Going by memory, i just remembered/assumed the article as having alot more detailed info. Here's a link that i probably stumbled upon on the pumpless threads.
http://www.plees.f2s.com/ec/pas-cool/pas-cool.htm
WarriorII said:For those not familiar with it, this operates on the same principle as an air conditioner.
I wonder what "fluid" they have inside the system? R12 is being phased out, I wonder if it's alone 134a or a house hold type refridgerant?
WarriorII said:II wonder what "fluid" they have inside the system? R12 is being phased out, I wonder if it's alone 134a or a house hold type refridgerant?
WarriorII said:Macklin01 -
if ya look around at some / most of the A64 set ups - they reall don't have that big of an overclock at all.
- I mean really, it's not like the old days where 500+ mhz got squeezed out of a cpu.
now we're lucky to see 200mhz, maybe a bit more.
Aaron Burton said:Keep in mind that the electricity that you would use to maintain a motor in a watercooled PC system would use fossil fuels, and also release greenhouse gasses. The trick is to find the best solution possible for a given problem.
BeerHunter said:I don't see what the big deal is. Looks identical to a heatpipe heatsinks out there like XP90 but with a longer "pipe" up to a larger "sink". Have no idea how he got a patent on this extension/enlargment idea. Unless I'm just missing something???
