G.Skill Announces Z5i Mini-ITX Pentagonal SFF Chassis
G.Skill just announced the Z5i Mini-ITX pentagonal-shaped chassis. This uniquely styled small form factor case features a pair of contoured tempered glass panels that enclose the left, front, and right sides, and a dual-chamber design that allows for up to 280 mm of radiator space. Pricing and availability are not yet available. Below is G.Skill’s official press release.
G.SKILL Announces Unique Pentagonal Z5i Mini-ITX PC Case
(15 June 2021) – G.SKILL International Enterprise Co., Ltd., the world’s leading manufacturer of extreme performance memory and gaming peripherals, is thrilled to announce the Z5i mini-ITX chassis, a minimalistic and compact PC case constructed for high-performance, small-form-factor (SFF) builds. The Z5i features a sleek pentagonal prism case design with curved tempered glass side panels on both sides, and is capable of supporting liquid cooler radiators of up to 280mm and high-end triple-slot graphics cards of up to 330mm in length for a small, yet powerful PC build.
Uniquely Crafted for a Clean Desktop
The G.SKILL Z5i is a uniquely crafted mini-ITX case with curved 4mm tempered glass side panels that wrap around the precision-made single-piece aluminum exterior frame to form a 5-sided case, showcasing the dual-chamber design so internal hardware components can be viewed from both sides. To enable a cleaner workspace, the Z5i is created with a bottom-facing motherboard I/O panel so cables can be neatly and easily managed.
Compactly Designed for High-End Hardware
Designed to accommodate high-end hardware components, the Z5i mini-ITX case supports large 3-slot graphics cards of up to 330mm in length and supports up to a 280mm AIO radiator or two 140mm case fans in the rear for cooling. Ample data storage is also essential in a high performance system, so the Z5i is constructed to house up to three storage drives, including two 2.5” SSDs and a third convertible 2.5”/3.5” SSD/HDD drive space.
Front Panel Connectivity & ARGB Lighting
For easy access to external USB devices, the front panel on the Z5i is equipped with two USB 3.0 ports and one USB 3.1 Type-C port, providing convenient high-speed connections to modern portable storage devices or smartphones. The Z5i also integrates ARGB to provide ambient underglow case lighting via the standard 3-pin 5V RGB header on supported motherboards, and controllable with motherboard lighting software for easy lighting customizability.
Designed with Excellence
Designed to support high-end components and integrating unique features into the compact mini-ITX form factor, the Z5i has received worldwide recognition for its product design as the recipient of “iF Design Award 2021” and “Red Dot Design Award 2021”.
About G.SKILL
Established in 1989 by PC hardware enthusiasts, G.SKILL specializes in high performance memory, SSD products, and gaming peripherals designed for PC gamers and enthusiasts around the world. Combining technical innovation and rock solid quality through our in-house testing lab and talented R&D team, G.SKILL continues to create record-breaking memory for each generation of hardware and hold the no. 1 brand title in overclocking memory.
-John Nester (Blaylock)
Recent Articles
About John Nester 399 Articles
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Loading new replies...
Avatar of EarthDog
EarthDog
Gulper Nozzle Co-Owner
78,884 messages 5,382 likes
This thing looks neat to me...
Reply Like
Avatar of Blaylock
Blaylock
8,140 messages 1,173 likes
There are several features in this chassis that I'm curious about. Hopefully, we receive a review sample so we can put her through the paces.
Reply Like
Avatar of BugFreak
BugFreak
2,476 messages 735 likes
Pretty neat looking chassis there but seems pretty limiting though.
Reply Like
Avatar of Blaylock
Blaylock
All m-ITX cases are limiting.
Reply Like
Avatar of EarthDog
EarthDog
Yeah, it won't fit my 13" GPU (looks like it's good for 12" though), but...it will fit a 2x120/140mm AIO, I'd gather a couple of HDD/SSDs...
...wondering what the max PSU size is though.
After weighing this out, I just don't think I can ITX as I have too many M.2s in use (ideally I'd have three).
Reply Like
