Table of Contents
Today, Phanteks released the Glacier G30 Aorus water block for Gigabyte’s Aorus RTX 3080 and RTX 3090 Master and Xtreme GPUs. These full-cover water blocks feature a nickel-plated copper plate with an aluminum backplate for increased thermal transfer. Color options are either black anodized or chrome and the price is $200 and $209 respectively. Read the press release below for complete details.
Phanteks releases new Glacier G30 AORUS blocks and backplates for the GIGABYTE AORUS RTX 30 Series
Rotterdam, The Netherlands – June 11th, 2021 – Phanteks today announced its high-performance Glacier G30 AORUS blocks and G30 AORUS backplates for the GIGABYTE AORUS RTX 30 Series graphic cards. The new Glacier G30 AORUS water block designed specifically for the Gigabyte AORUS RTX 3090/3080 Master/Xtreme cards provides a high-performance water-cooling solution, and the new backplate provides cooling to the back of the PCB while creating a clean aesthetic look.
The water block uses premium materials that feature an aluminum cover, nickel-plated copper base, clear transparent acrylic top, and industrial VITON sealing to ensure the best reliability and longevity. The water block is developed and designed to directly cool all the critical components and cover the entire PCB. A higher level of heat dissipation and transfer with the 6mm copper base and greater fin surface area with reduced flow resistance for outstanding cooling performance. The water block comes with integrated D-RGB lighting that beautifully complements your build and can sync with Phanteks’ D-RGB accessories and compatible third-party products.
And lastly, the CNC machined Glacier G30 AORUS backplate comes in black anodized or chrome plating aluminum, covers the whole length of the graphic card with a minimalistic and elegant design that features thermal pads to help improve cooling of the RAM and VRM on the back of the PCB.
GLACIER G30 AORUS BUNDLE
Black Anodized $199.99/ €199,90 / £179.99
Chrome $209.99/ €209,90 / £189.99
Recent News
No replies yet
Loading new replies...
