MSI Announces Radeon RX 6700 XT Graphics Cards
Recently MSI announced its latest addition to the RX 6000 Series lineup, the RX 6700 XT. Their newest offering will feature AMD’s RDNA2 architecture and 12 GB of GDDR6 memory. The complete lineup consists of three SKUs comprising the RX 6700 XT 12G, RX 6700XT Gaming X 12G, and  RX 6700 XT MECH 2X 12G OC. Pricing, core clocks, and power consumption have not been released but availability is projected for mid-march. Here’s to hoping they can meet this timeframe. Below is the press release from MSI.
MSI unveils custom Radeon RX 6700 XT graphics cards
[Taipei, Taiwan] As a leading brand in True Gaming hardware, MSI is proud to announce a new graphics card line-up based on the AMD Radeon™ RX 6700 XT GPU, uniting the latest in graphics technology, high-performance circuit board design and advanced cooling.
GROUND-BREAKING AMD RDNA™ 2 GAMING ARCHITECTURE
AMD RDNA™ 2 gaming architecture at the core of the MSI Radeon RX 6700 XT Series is designed to deliver the optimal combination of performance and efficiency. It features a breakthrough high-speed design and enhanced power efficiency, designed to deliver higher performance with lower power consumption, and a new cache hierarchy designed to minimize data movement, latency and power usage.
  • AMD Infinity Cache – A high-performance, last-level data cache suitable for 4K and 1440p gaming with the highest level of detail enabled. 96MB of cache on the GPU die delivers up to 2.5X higher bandwidth at the same power level as traditional architectures[i] to provide higher gaming performance.
  • AMD Smart Access Memory[ii] – Unlocks higher performance when pairing AMD Radeon™ RX 6000 Series graphics cards with AMD Ryzen™ 5000 or select Ryzen 3000 Series Desktop Processors and AMD 500-series motherboards. Providing AMD Ryzen processors with access to high-speed GDDR6 graphics memory can deliver a significant performance uplift.
  • DirectX® Raytracing (DXR) – Adding a high performance, fixed-function Ray Accelerator engine to each compute unit, AMD RDNA 2-based graphics cards are optimized to deliver real-time lighting, shadow and reflection realism with DXR. When paired with AMD FidelityFX[iii], which enables hybrid rendering, developers can combine rasterized and ray-traced effects to ensure an optimal combination of image quality and performance.
[i] Measurements calculated by AMD engineering. Measuring 1440p gaming average AMD Infinity Cache hit rates of 60% across select top gaming titles, multiplied by theoretical peak bandwidth from the 12 64B AMD Infinity Fabric channels connecting the Cache to the Graphics Engine at boost frequency of up to 1.94 GHz. RX-624
[ii] Smart Access Memory technology enablement requires an AMD Radeon 6000 series GPU, Ryzen 5000 or 3000 series CPU (excluding Ryzen 5 3400G and Ryzen 3 3200G) and an AMD 500 series motherboard with the latest BIOS update. BIOS requires support for AGESA 1.1.0.0 or higher. Download latest BIOS from vendor website. For additional information and system requirements, see https://www.amd.com/en/technologies/smart-access-memory. GD-178.
[iii] For additional information, see https://www.amd.com/en/technologies/radeon-software-fidelityfx. GD-172
GAMING series
MSI brings the GAMING series with the iconic TWIN FROZR 8 thermal design to the MSI Radeon RX 6700 XT graphics card. Compared to the previous generation, the dual fan design has been improved with TORX FAN 4.0, binding fan blade pairs together with an outer link to focus airflow into the TWIN FROZR 8 cooling system. The heatsink features advanced aerodynamic and thermodynamic technologies for efficient heat dissipation, reducing temperatures while maintaining high performance. A new design emphasizes the dazzling Mystic Light RGB infused into the card. Gamers can easily control and synchronize LED-lit components with the upgraded MSI Dragon Center software.
MECH Series
The MECH series makes its return with the MSI Radeon RX 6700 XT graphics card, now enhanced with MSI’s acclaimed TORX FAN 3.0. The performance-focused MECH design maintains the essentials to accomplish any task at hand, whether it’s for play or for work. A powerful cooling system, reinforcing brushed-finish backplate and the solid industrial aesthetic make the MECH card suitable for any PC build.
MSI AFTERBURNER
MSI Afterburner is the world’s most recognized and widely used graphics card overclocking software. It gives you full control of your graphics card and enables you to monitor your system’s key metrics in real-time. Afterburner gives you a free performance boost for a smooth in-game experience thanks to higher FPS.
MSI DRAGON CENTER
MSI Dragon Center integrates all MSI software for components, desktops, laptops and peripherals into a single platform. The all-new software features Frozr-AI, which allows users to have their system fans respond dynamically? to GPU and CPU temperatures. Gaming Mode, which instantly optimizes PC hardware for the best gaming experience, including SSD, monitor and network settings. This budding new software platform will continue to improve and evolve, providing more unique functionality and benefits for MSI users.
AVAILABILITY
The new MSI Radeon RX 6700 XT graphics cards are expected to be available beginning in mid-March 2021.
Specifications
Model NameRadeon RX 6700 XT GAMING X 12GRadeon RX 6700 XT MECH 2X 12G OCRadeon RX 6700 XT 12G
GPUAMD Radeon RX 6700 XTAMD Radeon RX 6700 XTAMD Radeon RX 6700 XT
InterfacePCI Express x16 Gen 4PCI Express x16 Gen 4PCI Express x16 Gen 4
Stream Processors256025602560
Core ClocksTBDTBDTBD
Memory12GB GDDR612GB GDDR612GB GDDR6
Memory Speed16Gbps16Gbps16Gbps
Memory Bus192-bit192-bit192-bit
OutputsDisplayPort x 3 (v1.4) / HDMI x 1 (Supports 4K@120Hz/8K@60Hz and VRR as specified in HDMI 2.1)DisplayPort x 3 (v1.4) / HDMI x 1 (Supports 4K@120Hz/8K@60Hz and VRR as specified in HDMI 2.1)DisplayPort x 3 (v1.4) / HDMI x 1 (Supports 4K@120Hz/8K@60Hz and VRR as specified in HDMI 2.1)
Power ConsumptionTBDTBDTBD
Power Connectors8pin x 28pin x 28pin x 1 / 6-pin x 1
Card Dimensions279 x 131 x 58 mm247 x 131 x 51 mm267 x 110 x 40 mm
Weight (card/package)1179 g / 1764 g921 g / 1393 g908 g / 1374 g
-John Nester (Blaylock)
Recent Articles
About John Nester 399 Articles
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Loading new replies...
rainless
1
10,575 messages 113 likes
Pfft... Doesn't matter. The scalpers will just get to that, too.
Reply Like
