Welcome
to the forums.
I have not seen any of us that help most of the posters overclock their cpu/system, that ever recommend software overclocking.
AMD has a pretty good overclocking guide for their own AOD software for their cpus on motherboards with an AMD chipset. You can google AMD AOD and likely find a tutorial on using it.
Some Asus mobo's have a % overclock in the bios and you could use it if you are into AUTO overclocking. Probably an Asus mobo forum is best suited to describing Asus Auto overclocking.
If you choose however to learn the bios overclock, then there are a few things that would be best to do at the beginning since it is best started at the beginning.
There is either a 'number' of posts limit or a time limit before you can make a signature that is extremely important to the process.
My how to put up Sig at OCF.
New Shortcut method for putting a Signature with your system information following your every post so people can know what is in the case that they are trying to assist with. You can use something like what is shown in my signature as a good template of needed information Thank you.
Now as soon as possible get a signature done. Again not sure I know the limit in place before you can make and display signature.
Then it is the very best thing to do starting at the beginning to check the system for baseline stability. No sense in beginning an overclock process if the board is not stable at the outset. It just makes us chase our tails.
So you put prime 95 into blend mode testing and you have HWMonitor open on the desktop so that HWMonitor is running and logging min/max temps and voltages. Run the P95 in blend mode for at least 20 mins and hopefully your system is stable and does not BSOD or fail a worker or some other shortcoming that would indicate the sytem is not stable at even stock settings.
Then capture HWMonitor with a snipping tool so the whole screen is not displayed and attach the capture to the forum. There are three CPUz captures that need to be done and attached to the forum as well.
A good post that shows HWMonitor and three CPUz captures looks like this post right here. A good post showing 3 cpuz and HWMonitor.
That should get you on the same page we work off of, day in and day out to coach a good overclock using bios to do so. Good luck to you sir.
