In some respects I agree with Woomack about DDR3-2400
We have already had one user come thru the AMD Mobo Forum section with the Kingston Beast stuff. He also had been posting for help at another site.
This is from the other site location.
Has Problems as well with Sabertooth 990FX R2.0
djsmeegy
February 11, 2014 5:28:36 AM
- ASUS Sabertooth 990FX R2.0
- KHX24C11T3K2/16X
- AMD FX9590
These modules are not in the support list by ASUS. But I want to know if you can recommend me some timing settings for 2133 or if I should OC to 2400MHz .
I have two days for some playing with that, then I'll decide if I return ram modules and choose different.
So Ive tried OC to 2400MHz with timings and it seemed to be OK, but in windows there have been random reboots. So again Ive run memtest and found 10 errors in 2nd testing part of 4. So I will return those damn memory cards.
This is what "djsmeegy" replaced his Kingston Beast with and was glad they were low profile for use even with large air coolers.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231560&ignorebbr=1
G.SKILL Ares Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-1866C10D-16GAB
I looked at the list of parts used by the OP "Nenad" and with an air cooler on the cpu and an Nvidia video card, there is really no need whatsoever for DDR3-2400 and just about certainly not with AMD system.
He may do far better with less wear and tear one one's psyche, to RMA the Beast if he can and get something more likely to work without having to completely test out and try to adjust ram timings.
"djsmeegy" had issues even after he got the DDR3-2400 to run but just like Woomack said he expected, "unexpected" BSODs and that is what "djsmeegy" experienced.
Time to get different ram and begin to use the computer is my best guess.
RGone...
