Xeon, that is impressive!! I don't know that much about refrigeration, but it sounds like a real winner.
This might be a dumb question, but why liquid cooling? I realize it's better than conventional fans etc.. but does liquid really cool the absolute best?
I looked up cooling directly with refrigerants and found a bunch of not-so-good attempts, but the thing I noticed was that all of them used the same kind of "seat sink". --Basically, a hollow copper plate that the refrigerant flowed through. One said that it only kept his CPU at 29C???
Here's the Idea I came up with to "experiment" with a non liquid alternative:
I'm thinking of using a few peices of solid copper plate as a container and braizing a line of 1/4 inch copper tubing to it (in a zig-zag shape). Then braizing the rest of the box together so it is water tight with a 1/4 inch nipple, a float switch and a small 12V pump (probably located outside the case) to allow for condensation removal with the copper lines running from a small window A/C unit.
do you think it's worth investing the $50US +/- and time? I already have an A/C unit (uses 134a and needs to be recharged anyway).
PS: My knowledge of HVAC is thus....
I worked for an HVAC company for 3 years installing A/C units and Duct. LOL
So, I know how to use a reclaimer, Braize/Sweat pipe etc... But the engineering side....well..........The above Idea is my imagination
