So between the FRIO, the Nic C5 and the EVO, what would you guys choose?
The list is getting shorter!
The NiC C5. Only better than the Frio because chances are the Frio will interfere with a ram slot.
Also because if it doesn't clear the ram the way the fan is mounted on the Evo you can just slide it up the heatsink or put it in pull configuration.For the money the Evo would be my choice.
My 6350 runs a cool 4.6 with the CM 212
Refurbished, 30-day warranty on an AIO, no thanks.
Kills air and if it works in the first 30, its likely to last for a while. Just because its refirbed doesnt mean It was just the rad fan screw holes where just stripped out from user failure lol.
I voted NiC C5. Why did that get thrown out the door? It's a better performer than the EVO and won't block a ram slot like the Frio.
Agreed Mr Scott. I only chose the Evo for the price as it seems as if the OP only wants something quiet and not for really pushing overclocks on.
