Advice for setting up Ram ( X2 440o AMD )
diehrd
Senior SMP Gawd
NY
Ok I finally got the processor running stable at 2750..(X2-4400) DFI-SLI-DR main board With G-Skill 4400 LE
But the ram eludes me,,I have followed some other peoples settings BUT I think possibly I have 1 or 2 settings wrong for my system BUT I am clueless as to what I should change first.
It is rock stable at these settings,Super Pi,Prime 95 and games perfectly as well as runs flawlessly..However I would like to tighten it up as much as i can so i figured someone could offer advice ?
Ok I am at 10x275 ( x 2.5 )
Here from top down is how I have it set.
CPC enabled
TCL: 2.5
TRCD: 4
TRAS: 8
TRP: 4
TRC: 11
TRFC: 20
TRRD: 2
TWR: 3
TWRT 2
TRWT: 2
TREF: 3632
TWCL: auto
DQS SKEW: increase
DQS SKEW VALUE : 200
DRAM DRIVE STRENGTH: 7
DRAM DATA DRIVE STRENGTH 3
MAXASYNC LATENCY : 08
READ PREAMBLE TIME : 5.0
IDLE CYCLE LIMIT : 64
DYNAMIC COUNTER: ENABLED
R/W QUEUE BYPASS: 16X
BYPASS MAX: 7X
32 BYTE GRANULATION: DISABLED 4 BURSTS.
RedDragonXXX
Senior RAM Pornographer
Jacksonville, FL
Up the TRRD and TRWT to 3, lower your TREF to 3120, up the DQS SKEW VALUE to 255. Try changing these all at once or first do TRRD&TRWT at 3 and if that's not stable, keep them at 3 and change the rest of the settings as I provided above.
Hope that helps.
P.S. At 275MHz you should be able to do 2.5-3-3-6/7 with the LE's.
diehrd
Senior SMP Gawd
NY
Thanks I set it and will try a benchie and a game to make sure I am still stable..
RedDragonXXX
Jacksonville, FL
The setting that I gave you above will give you better stability but if you want performance then you should do it at these settings:
2.5
3
7
3
7 - 11 if not stable
15 - 20 if not stable
2 - 3 if not stable
2 - 3 if not stable
2
2 - 3 if not stable
3072 - 3120 if not stable
1
Increase
255
7
3
8
5
256
Enable
16X
7X
Disable 4 Burst
Also remember that these are TCCD's and not TCC5 so don't go over 2.9V on the Vdimm. At 275MHz and these settings 2.8V should be enough.
diehrd
Senior SMP Gawd
NY
Ok perfect .. I can run those settings and it is stable in Pi and sandra as well as battlefield 2 for a round..Not a perfect test but Bat 2 usually gives me big issues right up front if my memory is not stable..
You rule >
RedDragonXXX
Jacksonville, FL
You rule >
Always glad to help the fellow OC'ers :D
