- Jan 12, 2012
Is that a decent motherboard Woomack? I'm sure you wouldn't be linking it if it weren't but my brain tends to stay with what I know on the AMD side. With the Fx processors, we have seen a lot of issues with the Gigabyte boards through the different revisions, some are great boards and some are junk.Z87X-OC is $10 cheaper -> http://www.canadacomputers.com/product_info.php?cPath=26_1207_1206_1201&item_id=060868
Sorry I missed that Woomack. It seems on the Intel side most Z87 boards will Oc the K series Cpu's well it's just a matter of what goodies you want and how much you're willing to pay for better parts/components on the mobo.I have that Z87X-OC as I said few posts ago.
I'm pretty sure it isn't available on the Hero Johan and as you know now it's a pretty good option to have for benching.I'll have to look again but the ROG connect isn't available with the HERO is it???
Ha Ha Crack here get ya Crack!Ya I went and checked hero no formula yes. Ah what the hell it's only $100.
If Shamino really quit ASUS team then I wonder how future ROG boards will look like. Most previous Intel ROG boards were improved till Shamino was testing them so usually ~3 months after premiere. After this time you could barely see new BIOS with anything more than " improves stability" or added new CPU microcode. Simply if board issues were not solved in that 3 months then were never solved.
Its a great board for the money... without a doubt.Is that a decent motherboard Woomack? I'm sure you wouldn't be linking it if it weren't but my brain tends to stay with what I know on the AMD side. With the Fx processors, we have seen a lot of issues with the Gigabyte boards through the different revisions, some are great boards and some are junk.
It's not hard to do EDDo not let the name badge confuse you.
Good to hear you're liking your new toy.Just wanted to update the thread. I got rid of the Killer and picked up the ASUS Maximus Hero and couldn't be happier I did. Have the same 4.5 OC with .04v less. I can run the cache up to 45-4600 which wasn't possible before. Have done some benching with it and kinda getting the hang of it now. The funniest part is...... I set the auto "CPU UP" to 4.6 in the bios and it runs stable with P95 plus all the Green stuff works. That was the easiest OC I have ever done. It runs prime with 1.396v and that's about the limit of the TT AIO. I have to say either the killer was defective or the Hero is just that much better. Never tested the new board using Aida64 but I still don't believe it's sufficient for stability.
Did you also get it to 4.6 on your own? I'm just curious if it's over-volting it by a bunch over what you found.I set the auto "CPU UP" to 4.6 in the bios
No haven't tried really. The volts would fluctuate between 1.37-1.396, I actually just took that as a starting point for some of my benching. Just switched over to manual voltage and adjusted as required. I have my 4.5 OC but lately have just been setting it to the AUTO 4.6 if I'm not benching or Folding. I should give it a trial at some point but there's only so much time and benching is more fun. Ha ha ha Also when I get this thing plumbed in to the main line it'll all change anyway.
Meaning buy another one to see if it will OC on lower voltages?I'm starting to think that maybe I could try one more 4670K ... my last one needed 1.4V+ for 4.4GHz
