Very nicely done speedking, that's a great cache clock!
Thanks.
The PC runs through some benchmark with a 4.7GHz cache (SuperPi, 3Dmark series...), buts XTU/Cinebench have to [email protected]. Unless I put through it too much volt at my taste!
Thanks.
Usually cache has to be 200-300MHz below CPU clock and to keep it stable at x48+ ratio it needs higher voltages ( I mean much higher ).
you probably have to bump ring voltage to make it run higher but in most tests it won't make any difference anyway
here I had 5200MHz cache and it was only on ss cooling ( CPU voltage isn't correct ):
LOL I would think if it was Woomack even under SS 2.2 would kill it rather quickly?!?!CPU voltage isn't correct
I have to bump voltage for 43x-44x to boot/run.
For me I run 1.25v for 45-4600 and 1.32ish volts for 4800 depending how hard the bench is sometimes up to 1.35
Seeing how cache makes little to no difference in most benchies, I rarely touch it. That said, even at 5Ghz+ I left it at stock 3300Mhz with no problems. I believe that is a myth. Or if it isn't, I have never run into that issue for some reason. Not in Haswell, not in HW-e either.Usually cache has to be 200-300MHz below CPU clock and to keep it stable at x48+ ratio it needs higher voltages ( I mean much higher ).
@devlos -> thats some sick voltages for 5.0 ghz man! Thought mine was good
Thanks, I thought it was decent. I'm new to amd so I don't really know whats good. I also don't know if disabling cores will let you have lower volts. With all cores active it only needs 1.41-1.42v
On the subject of cache voltage I ran my 4690k cache at [email protected] on accident, I meant to hit 1.19v but hit 1.9 I ran xtu a few time with it like that anyway and ended up with my best score.
I've been meaning to check that thread out, I could use some tips on getting these AMDs clocked up.
I prob won't stress it for stability other than with benches because it's not going to be used for anything other than benches and overclocking and Rosetta@H
