Nice run Blaylock, just cross off the 5400 and make it 5000 with paint and you're good to go.This was the best run I could muster on this Frankenstiened ASRock board.
Peanutbudder, have a look through these two threads and maybe Woomack can guide you on what Ic's to look for. I can tell you the Psc based Ic in the Ripjaws I have are really good. They are the same as the ones Metalracer has in his post #47 they'll do 2400 and also run at 1600 at really tight timings. I've run mine at 1600 with 6-7-5 timings on my AMD's and 2400 with 7-11-8 on the 4770k. They're tough to find though.Thanks guys for all the replies I will start looking around for better kits. If it comes down to it and I get impatient I will pull the trigger on the 2400mhz cl9.
Yessir!Some nice runs there guys, was that XP Manny?
I'll make a run on W7 in a bit, working on the timings now, sun is beating on the Rad now so I don't know if I'll have enough cold to keep this whiny little chip at 5.0 much longer.I still haven't gotten around to trying that on my Z87 yet. What kind of gains did you get or don't you have any real comparison
Yes where's my FX?!?!?They can be temperamental little buggers can't they.
Nice run Devlos considering you're 200 Mhz shy of 5.0Devlos / 4690k / watah / 6.30.469
1.6v on ram.
Actually Woomack that wasn't the run I commented on, originally he posted a 6.36 run at 4800, he must have changed it or I'm losing my mind which is also possible.More like 80MHz
Btw Devlos, this memory is probably scalling up to 1.7V+ and maybe you can make it run at 8-8-8/8-8-9 2133. I don't think you make much higher clock.
Also set Command Rate to 1N. On haswell it should work without issues.
Thanks at least I know I'm not losing my marbles.Mandrake was right when he posted his comment but I bumped the cpu up and ran Spi again then edited my sub to what it is now, 80MHz off not 200.
The original was this
5GHz is giving me trouble (too hot to push 1.5v) so I did the run on what I could. I'm going to give the ram a nudge tonight when I try again, they have taken everything I've done so far without any issues, even survived the semp145 and 990fxa-ud3 death.
I don't think even the last 80MHz could shave off enough time to take the lead.
