- Jan 12, 2012
Callin me out eh?
Yes it took some cold on the entire system to make that happen - It also helps that temps outside have been good as of late but not over the last few days. As stated, my stuff is outdoors (The shack) all the time with whatever ambient temps are out there when I do a run. If it's nice and cold out, that's prime time for me to get busy.
I just turn it on, fire up the blowers and let it sing.
Here's my best at it so far..... Done in said cold outdoor temps with the blowers and all going.
http://hwbot.org/submission/2650491_
Not at all Doc I know you're good at this bench but if you look at the guys with the 6300 their NB is 2600 and the ram is Meh, Looks to me like they just made a half arsed attempt and cranked up the speed. There was no effort put into that it seems very obvious too.
Best I could do for now.. Maybe drop the FSB down a bit and I can get into 6 core. Going from 2 to 4 dropped it a whole 24 seconds at the same speed.
Going the wrong way bro. SPI is single threaded. Drop to 2 or even 1 core and bang up your OC.
Well heres the thing:
1) my mobo wont lock 7 cores, only 6 so minimum 2 cores.
2) at 2 cores I was looking at 15:45 just using 4 downed it to 15:20
3) cap is 5.005 so I am at the cap already. 25x200.0 is 5Ghz so there is no more OC to go under the cap.
5Ghz +0.1% so the actual cut-off point is 5005.
Dang it!... No "skillz" with this bench so far... I seem to have much work to do.
Not to mention my 4670K is RMA so I stuck trying with a G3258. Best I posted so far is 6.44 sec.Yea, this one you have to actually work to get your scores. I think benchmarks is more about the users knowledge than the hardwares ability.
DOH! Didn't know there was a cap now.
Anyhow, SPI is still single threaded, so whatever you think you gained by upping cores is a placebo. You did something different between your 2 and 4 core runs.
5005 is over the cap BTW.
I understand what you're saying but...........I don't care if you run 40 cores, it will not make a difference to a single threaded app.Yes, 5005 is the cap but if you see my bus runs hot at 200.9 which is 5050 and over the limit
The only thing I changed was going from 2 to 4 cores..
