You can always get the Noctua NH - D14 which is better than the H100i, but as ShrimpBrime and RGone said, you need to get rid of as much hot air within the case as possible if you want to get up to 4.1GHz without throttling.
Here ya go. This should help some.
http://www.overclock.net/t/1144409/...compatibility-thread-page-1-for-full-listings
Yeh man I saw that previous where fans on top of case but can Yeh get fan guards so don't touch as kids about.. Thas why I didn't choose that
True, but H100i won't match the D14 and we're talking about ~50$ less which the OP can use for fans to improve his air flow. Ofc, if there was room in ur budget for a custom loop that would be your best bet for the clocks u want but, personally, I would go for the Noctua since it's cheaper and it will perform better than the H100i.
Kids only learn once HAH!
well, looks like sub 3.8ghz. THe D14 might do it, But I'd be really sure there's a lot of case flow. That cooler needs as much air flow you can throw at it.
Haha true well I plan on filling case with push/pull but want cool plus quiet I know only true way is wc but then that could b close £200 for just cooling
