XTX CF wannabe Benchmarker
Hi OCF xtxers
I just made it through the 88 pages of this awesome Post. Thank-you to all that have put the time in to fine tune these beasts. I have a couple of questions, mainly dealing with 1900CF with XTX1900X and the ATI Tool. They may have been answered in previous posts I really saw a lot and took in little.
I know its a long winded post but I wanted the variables made available for the Gurus to check out.
I am trying to determine if the saved profiles map clock /vmod / Fan Settings settings to the card selected by buss number highlighted or does ATI Tool map both cards with same settings?
Presently, I open up Master card,select profile,hit save, then open slave, select profile, hit save, but I only get the option to select one profile to "Engage" when 3d apps are detected. Am I all messed up and ATI Tool is Keeping Clocks and Vmods of both cards on each separate profile or Am I activating the 3d apps correctly?
The present Setup and Settings :
1900CF master in Orange PCIE Slot, XTX Slave in Black PCIE Slot as per ASUS Manual on CF. Stock Fans with a Vreg 2" dedicated fan on Master Card
I have set core and mem values and made profiles for each, including fan settings, Vmods. I have CCC Running with ATI 6.14.10.0322 Drivers, ATI Tool 0.26
CCC Settings
Hotkeys Disabled
3d Settings
Anti-Aliasing = Let App Decide
Smoothvision = let App Decide
Catalyst AI = Advanced
Mipmap Detail -set to notch lower then Performance
Support DTX texture
ATI Over Drive in unlocked
Do not preserve settings at logon
Crossfire Enabled
ATI Tool Settings
Start up with Registry, default clocks with modified fan control.
1000 overclocking...if card has 2d/2d clocks switch to 3d when starting
Not affected by ATI Automatic clock switching
LOD +0.0
Any links to answers would be great, I have done one Bench on 06 so far but I think it bites for the equipment sitting here.
Thanks in advance.
Hi OCF xtxers
CCC Settings
Hotkeys Disabled
3d Settings
Support DTX texture
Crossfire Enabled
ATI Tool Settings
LOD +0.0
Thanks in advance.
