Yea i guess they didnt have the NH-U12P in stock or something when i purchased all the parts. I already ordered the "upgrade" from Noctua. Also i noticed that I should have taken the front vent panel off when i was cleaning, the case has filters on fans and the front intake filter was horrible lol I already re-applied the thermal compound, lets see what that does.
From your next post put in this one.
Yea temps still reach 70C...
I'm going to wait for this 90 degree upgrade part and will let you know of the outcome.
Okay we need to do some SERIOUS troubleshooting here so that turning the cooler is in fact a fix and not another failure due some super odd crap you are dealing with that if we could lay our eyes on the problem would just hop out at us.
1. > Measure the distance between the back of that video card and the blade center of that bottom fan on the CPU cooler.
2. > Make sure you do not have one of the fans mounted backwards on the cooler and the fans blowing AT each other. We had that on a push-pull a month or so ago and he even owned up to having done it. A real man.
3. > Put your hand between the back of the video card and Cpu cooler intake and see if it is very warm compared to the air in the room you stand in.
4. > It is hard to do but after enough practice you can tell if the metal on the top of the cpu is warped. How the heat sink compound looks laid out across the top of the cpu and the bottom of the Heat Sink itself can give good clues with practice. You may have to take the Heatsink off and take pictures of the top of cpu and bottom of cpu and post for us to see or else flatness can be checked with a very good straight edge used for things like machine work.
5. > We need to ensure that the attaching mechanism is putting enough pressure on top of the cpu. The way paste is laid out can point to not enough pressure and I know many good cooler makers now make an increased pressure mounting system for the sure enough tweaker. I think I saw such at Noctua even. But you should not be able to twist that cpu cooler on top of the cpu after it is mounted and run at least 5 hours and shut down and checked after total cool off.
6. > Okay we got the checking done that I do the first time my stuff does not seem to run cool. I have done it so long and others as well, that from a distance we forget to say something about things we have done for years.
7. > So now for a test since there seem two fans in the top of that Lian Li case and there should be one capable of blowing right at that HSF assembly if it is turned around and made to draw air from the top of the case and let the Fan in the top of the case blow straight into the intake fan of the cpu cooler and see if the temps don't fall when doing so. I bet the temps will fall if all the rest of the stuff checks out as fine and passable.
One note here there seems to be a place for two fans in the top of that case and you may have only a single fan at the top mounted toward the front of the case and might have to move it to the rear hole in the case top.
Now if reversing the Cpu Cooler and the top fans blowing directions, lowers the temps...then changing the orientation of the Cpu cooler to blow out the rear will likely help.
Now that is what " I " really would have done when I found my temps just would not go down. Good luck man.
