storm-chaser
Disabled
- Sep 2, 2011
- Upstate NY
There is absolutely no way that you have minimum voltage 1.35v for 3.8 and 1.4v for 4.2...
Usually 0.04-0.06v is needed for a 100 MHz jump, but for you that would be .012 which is impossible...
@OP,
If you can get 3.9 at 1.45v, (did you have 3.8 @ 1.4v before?) then what is the temperature at that speed/voltage?
There is a way. I've run multiple Phenom IIs (965. 970T) on stock voltage at high clock speeds. the 965 ran 3.8 @ 1.345v stable and the temps didnt get much above 110*F. The 970T in 4 core mode ran 1.440 at 4000mhz. The temps rarely went above 100*F. Sure, prime wasnt stable for more than 40 minutes, but in day to day use they were completely stable, 100% uptime.
