So Futuremark 3DMark + TimeSpy v2.1.2852 was released today... a pretty DX12 benchy from FM.
Have a download (or update through the already installed version) and post up your scores! Please format the screenshot using standard hwbot requirements which need to be visible in the SS (See next post for an example):
3DMark overall score
3DMark subtest scores
CPU-Z CPU tab
CPU-Z Memory tab
CPU-Z Mainboard tab, ONLY required for submissions made with motherboard IGP
GPU-Z Graphics Card tab (Rivatuner may be used if GPU-Z fails to correctly report the GPU)
SCORE - USERNAME / CPU X.x GHz / GPU @ ACTUAL XXXX MHz (actual boost clock) / Memory clock XXXX MHz
Single GPU (Green = NVIDIA, Red = AMD, Blue = Intel)
11896 - jiccman1965 / 6950X @ 5.0 GHz / GTX Titan X 1643/1403
10970 - MetalRacer / i7 6950X 5.0 / Titan X Pascal @ 1974 / 1426
10738 - Vellinious / 6950X 4.6 GHz / Titan Xp @ 2061 MHz / Memory clock 2797 MHz
10,424 - Johan45/ i7 8700K @ 5.2/ GTX 1080Ti 2075/1650
10298 - Tír na nÓg / [email protected] GHz / GTX 1080 [email protected] / Memory Clock 6100MHz
9379 - Woomack / [email protected] / [email protected] 1623/1498 Stock FE cooler
9285 - JRClocker / 5820 K @ 4.3 GHz / Titan X Pascal @ 1923 MHz (actual boost) / Memory Clock 5103 MHz
9040 - Vellinious / 6950X @ 4.4 GHz / EVGA GTX 1080 FTW @ 2189 / 2789
8907 - jiccman1965/6950X/GTX 1080/water
8051 - Earthdog / 6950X @ 4 GHz / MSI GTX 1080 Gaming X @ 2101 MHz / 1402 MHz.
7999/ Johan45/ TR 1950X @ 3.9/ RX Vega64 1712/1005
7896 - OnDborder / 5960x @ 4.5 GHz / Asus gtx 1080 @ 1959 MHz boost clock / 1390 MHz
7787 - R_Pierce / i7 7700k 5.1 GHz / EVGA 1080 FTW Hybrid @ 2120 MHz / 5320 MHz memory
7780 - GoldieFoxx / i7 6700k 4.7 GHz / GTX 1080 (Zotac AMP! Extreme) @ 2101 MHz / Memory clock 1364 MHz
7481 - Johan45/i7 [email protected]/ GTX 1070 Ti/ 2113/2070
7466- Brutal-Force / 7900x @ 4.6 GHz / FE GTX 1080 @ 1877 / 1278
7393 - JRClocker / 5820 K @ 4.3 GHz / GTX 1080 @ 2088 MHz (actual boost) / Memory Clock 1251 MHz
7369 - Earthdog / 5820K 4.25 GHz / GTX 1080 @ 1987 MHz + 1264 MHz
7224 - DaveB / i5-8400 3.8 GHz / GTX 1080 @ 1919 MHz + 1100 MHz
7001 - Vellinious / 6950X @ 4.6 GHz / 980TI @ 1567 MHz (actual boost clock) / Memory clock 2153 MHz
6797 - mackerel / R7 1700 3.6 GHz / Vega 56 @ 1667 MHz / 900 MHz
6593 - Woomack / [email protected] / GTX1070 @ 2100MHz / 2227MHz
6608 - Vellinious / 5820K @ 4.625 GHz / EVGA GTX 980ti Classy @ 1562 / 2140
6371 - LutaWicasa / 6700K @ 4.5 GHz / MSI 1070 Aero @ 2088 MHz / Mem Clock 2351 MHz
6359 - LutaWicasa / 6700K @ 4.5 GHz / EVGA 1070 FTW @ 2076 MHz / Memory Clock 2295 MHz
6337 - Witchdoctor / 6600k 4.8 GHz / 1x GTX 980Ti @ 1558 MHz / 1952 MHz
6191 - Jeff G / 6700k 4.6 GHz / GTX 1070 @ 2088 MHz / 2050 MHz
6162 - Witchdoctor / 6600k 4.6 GHz / 1x GTX 980Ti @ 1529 MHz / 1923 MHz
6094 - Johan45/5960X @ 5.0/ R9 Fury @ 1160/573
5958 - mokrunka / i7 3820 @ 3.6 GHz / ASUS Strix GTX 1080 @ 1607 MHz (1734 boost) / 1251 MHz
5884 - Earthdog / 6700K 4.20 GHz / GTX 1070 @ 1987 MHz + 2027 MHz
5853 - mackerel / 6600k 4.6 GHz / Gigabyte Xtreme Gaming GTX 980Ti @ 1445 MHz / 2098 MHz
5726 - JrClocker / 5820K @ 4.3 GHz / GTX 980 Ti @ 1388 MHz (actual boost) / Memory @ stock
5694 - theELVISCERATOR / 4790K @ 4.6 GHz / EVGA GTX 980ti @ 1416 MHz + 1952 MHz.
5651 - Dominick32 / 3770k @ 4.20 GHz / FE GTX 1080 @ 2020 / 4200
5624 - mackerel / 6700k 4.0 GHz / Zotac GTX 1070 FE @ 1898 MHz / 2003 MHz
5212 - Johan45/R7 [email protected]/ RX580 1545/2186 Stock
4916 - dejo / 6700k @ 4.8ghz / GTX 1060 @ 2100 / 4658mem / Air on cpu and gpu
4898 - Woomack / [email protected] / RX480 1415MHz core, 2250MHz mem
4831 - mackerel / 6700k 4.0 GHz / Asus reference GTX 980Ti @ 1076 MHz / 1753 MHz
4691 - NeonCancerCandy / 6700K 4.55 GHz / GTX 980 @ 1451 MHz / 1820 MHz (+141/+116)
4590 - Johan45 / FX9370 @ 4.6/ GTX 980 @ 1453 / 2113
4545 - chevy350 / [email protected] / XFX R9 390X @ 1150/1650
4402 - shadowdr / I5 4690k @4.4 GHz / MSI GTX 1060 @ 2139 MHz / Memory clock 4455 MHz
4389 - Tír na nÓg / 5820 K @ 4.8 GHz / GTX 780 ti @ 1360 MHz (actual boost) / Memory Clock 8100 MHz
4288 - shadowdr / I5 4690k @4.4 GHz / MSI GTX 1060 @ 2025 MHz / Memory clock 2275 MHz
4205 - idfka / Intel 2500K @ 4.3 GHz / RX 480 @ 1425 MHz / Memory clock 2250 MHz
4070 - dejo / [email protected] / MSI gtx970 Gaming 4g / 1462core / 3956mem
3938 - NeonCancerCandy / 2500K 4.5 GHz / GTX 980 @ stock
3601 - mackerel / 6700k 4.2 GHz / EVGA GTX 970 SC ACX 2.0 @ 1317 MHz / 1753 MHz
2839 - Tír na nÓg / 5820 K @ 4.8 GHz / HD 7970 @ 1210 MHz / Memory Clock 1700 MHz
2364 - mackerel / 6700HQ 3.1 GHz / GTX 970M @ 1038 MHz / 1253 MHz
2289 - ||Console|| / 4670k 4.8 GHz / 950 gtx @ ACTUAL 1475 / Memory clock 1853 MHz
2106 - mackerel / 4360 3.7 GHz / R9 280X @ 1000 MHz / 1500 MHz
809 - dejo / Intel I7- 6670HQ / Iris Pro 580 / 1100core / 1200mem
753 - mackerel / 4360 3.7 GHz / R7 260X @ 1050 MHz / 1500 MHz
716 - mackerel / 5675C 4.1 GHz / Iris Pro 6200 @ 1250 MHz / 1200 MHz
Dual GPU (Green = NVIDIA, Red = AMD)
17323 - Charnelrot / i7 6950x 4.3 GHz /2x Titan X Pascal SLI @ 2035 MHz / Memory clock 1456 MHz
15972 - Vellinious / 6950X 4.6 & 4.5 GHz / 2 x GTX 1080 @ 2240 MHz / Memory clock 5556 MHz
15781 - jiccman1965/6950X/GTX 1080 SLI/water
15458 - Vellinious / i7 6950X 4.5 / 2 x 1080 @ 2202 / 5499
14145 - Vellinious / 6950X 4.6 GHz / 2 x 1080 @ 2113 MHz (actual boost clock) / Memory clock 2778 MHz
12852 - GoldieFoxx / i7 6700k 4.7 GHz / 2 x GTX 1080 (Zotac AMP! Extreme) @ 2050 MHz / Memory clock 1368 MHz
12611 - Vellinious / 6950X @ 4.6 GHz / 980TI @ 1531 MHz (actual boost clock) / Memory clock 2153 MHz
12581 - GoldieFoxx / i7 6700k 4.7 GHz / 2 x GTX 1080 (Zotac AMP! Extreme) @ 2025 MHz / Memory clock 1372 MHz
12343 - ginty87 / i7 7700k 4.9GHz / 2 x GTX 1080 Founders @ 2012 MHz / Memory clock 5049 MHz
11206 - Vellinious / 5820K @ 4.625 GHz / EVGA GTX 980ti Classy SLI @ 1493 / 2125
10243 - LutaWicasa / 6700K @ 4.6 GHz / GTX 1070 x 2 @ 2050 MHz / Memory Clock 2371 MHz
9347 - mackerel / 6700k 4.2 GHz / 2x GTX 980Ti @ 1427 MHz / 2001 MHz
9157 - Peanutbudder / i7 6800k 4.4GHz / 2 x GTX 980 (Nvidia Refrence) @ 1493 MHz / Memory clock 1918 MHz
8028[/COLOR] - Peanutbudder / 4790K 4.7 GHz / (2) 980 SLI @1322 MHz (1411mhz boost) / Memory clock 1888 MHz
8247 - Peanutbudder / 4790K @ 4.8 GHz / (2) GTX 980 @ 1508 MHz / Memory Clock 1878 MHz
DL: https://www.techpowerup.com/downloads/2744/futuremark-3dmark-timespy-v2-1-28522.1.2852
This major update adds Time Spy, a new DirectX 12 benchmark test. With its pure DirectX 12 engine, which supports new API features like asynchronous compute, explicit linked multi-adapter, and multi-threading, 3DMark Time Spy is the ideal benchmark for testing the DirectX 12 performance of the latest graphics cards.
New
Added Time Spy Stress Test - a new dedicated Stress Test for high-performing PCs running on Windows 10. Time Spy Stress Test is not available in 3DMark Basic Edition or 3DMark Time Spy upgrade in Steam.
CPU-Z CPU tab
CPU-Z Memory tab
