I changed things around and bumped myself up to a nice stable 3.8
Im still hitting a wall going to 4 but I think there is a little bit more room for me to bump voltages but Im def at the limits of my Hyper 212. I had my cpu voltage up to 1.35 and I was still crashing.
By the way below are my current settings should I leave my QPI/Dram Core at 1.2? Like I said my system runs fine, but i did notice that the xmp profile bumps it up to 1.35.
AI Overclock Tuner [Manual]
CPU Ratio [19]
Intel Speed Step [Disable]
BCLK Frequency [200]
PCIE Frequency [100]
Dram Frequency [1603]
UCLK Frequency [3208]
QPI Link Data Ratio [7218 mts]
CPU Voltage [1.2]
CPU PLL Voltage [1.8]
QPI/DRAM Core Voltage [1.2]
IOH Voltage [1.2]
IOH PCIE Votage [1.5]
ICH Voltage [1.1]
ICH PCIE Voltage [1.5]
Dram Bus Voltage [1.66]
Load-Line Callibration [Enable]
CPU Differential Amplitude [Auto]
CPU Clock Skew [Disable]
CPU Spread Spectrum [Auto]
IOH Clock Skew [Auto]
PCIE Spread Spectrum [Disable]
C1E Support [Disable]
Hardware Prefectcher [Enable]
Adjacent Cache Line Prefetch [Enable]
Intel Virtualization Tech [Enable]
CPU TM Function [Enable]
Execute-Disable Bit [Enable]
Intel HT Technology [Enable]
Active Processor Cores [ALL]
A20M [Disable]
Intel C-State [Disable]
I dunno why ur having such a hard time with getting a 4 GHz OC... For me it's extremely simple..BCLK @ 200, w/ multi of 20, 2x2=4Ghz, and you get to utilize your max ramspeed @ 1600. My vCore is extremely low, I got mine stable @ 1.24375v.
I also have LLC enabled, and I have all power saving features on as well, along with HT. Everything else I have set to AUTO, with XMP profile. Timings are the nothing-fancy 9-9-9-24. Idle temp is 40C. Have Corsair H50 cooling w/ push/pull configuration. Max temps reach mid 80's during LinX 20 test. Obviously this is just for benching, in real-word sceanrio (such as graphically-demanding games) temps hit max 73-75C after a few hrs of gameplay (mafia II, GoW, Crysis, etc)..
So this works for me.. Some might say temps are a bit high but I've tried everything and they always seem to stay around the aforementioned. I even RETURNED my i7 930 processor for a new one, AND exchanged the H50 for a new one, and temps still the same. Remounted cooling block several times but always same results. But oh well, everything's working and Intel themselves say 100C is the limit, which I am well below.
Whats the latest with your OC??
By the way, just for the heck of it I tried a 4.2Ghz OC, simply by raising the multi by 1, so 21x @ 200 Blck = 4.2 Ghz. Howver, I had to increase the vCore to almost 1.3 to get it stable, at which point it was idling a few degrees higher, and for the slight performance boost it gives (a couple hundred or so points more in 3dMark06) I figured it just wasn't worth it so Im sticking with my good ol' simple 4 Ghz OC.
