Table of Contents
A week or so ago, Alphacool announced two new All-In-One coolers utilizing its new NexXxos HPE radiators. Recently, they released these new high-performance radiators as stand-alone products for custom water cooling enthusiasts. The HPE-30 and HPE-45 compliment the NexXxos line-up with the same full-copper design. What makes these high-performance edition radiators different are the increased water channels and tighter fin density. A full array of sizes are available for 120 mm or 140 mm fans and pricing starts at $75. For a complete list of specifications see Alphacool’s press release below.
Alphacool NexXxoS HPE-30 and HPE-45 Full Copper Radiators
For more than a decade, Alphacool’s NexXxoS Full Copper radiator series has been one of the most powerful radiators on the market. With their incomparable performance, the radiators can easily dissipate even extremely high waste heat and have become indispensable in many areas of the cooling industry. Nevertheless, with the NexXxos HPE generation, it’s time for the next evolutionary step!
Alphacool NexXxos HPE Radiator
What does HPE mean? Alphacool’s NexXxos HPE radiators use the same materials as previous NexXxos models, but take it a step further technically. The number of water channels and copper fins inside the radiator has been increased. This means that a larger volume of water is in direct contact with the cooling fins and the heat transfer is improved enormously. The higher number of fin rows and their shortening also makes much more efficient use of the cooling surface. Comparison tests* with the conventional NexXxos radiator have shown that a significant performance increase of 4.5K is possible when using the HPE radiator. At higher ambient temperatures and higher fan speeds, the performance gap with the regular NexXxoS radiators even progressively increases, reaching a possible performance increase of up to 6K. Such a performance leap has never been seen in the past!
The NexXxoS HPE Radiator is initially available as HPE-30 and HPE-45 version. The common variants (120/140/240/280/360/420/480/560mm) for 120mm and 140mm fans form a rich offer, in which everyone should find something. The HPE-20 and HPE-60 versions will follow in the near future. Smart and Efficient!
Alphacool NexXxos HPE-45 420mm Radiator
(* Test setup: NexXxos ST30 360mm radiator vs. NexXxos HPE-30 360mm radiator with Eisbaer cooler and 3x 120mm Rise Aurora fans and on Asus Prime x299 motherboard with Intel i9 10900x CPU with 350W waste heat)
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
It seems like everyone is getting into the All-In-One CPU cooler business these days. Even the well-established case- and accessory-maker NZXT has gotten into the act, offering the Kraken line of CPU coolers. The Kraken lineup comes with room for one or two fans, at 120 mm and 140 mm. They always cool well in reviews. But the updated line promise to cool quietly as well. So let’s have a look at the X31, shall we?
Alphacool has just announced its latest line of G1/4 quick-release nylon fittings. Designed to save space, these have the ability to mount directly to components and said to improve bend radii and the overall aesthetics of your custom loop. Here is the press release from Alphacool.
Alphacool has announced its Core Distro Plates for all custom water-cooling enthusiasts. Constructed of clear acrylic with chrome-plated brass fittings and addressable RGB lighting, the new Core Distro Plates are sure to look fantastic in your next build. Four variants are available with two offerings in 240 mm and two in 360 mm sizes each compatible with VPP/D5 water pumps. Pricing starts at $172.86 and is available on Alphacool’s website. For complete details, see Alphacool’s press release below.
Their rads are pretty good. I was using them in many projects. They could work some more on the design. Stuff from Watercool or Barrow looks better and doesn't cost more (no idea about the Barrow's performance). I mean this is cooling for enthusiasts, while it looks pretty standard and not much different for long years.
I will check 120x45mm Alphacool rad soon. It's from older series but not much different than the new ones.
Alphacool radiators were always good and slightly cheaper than the competition. There are also many unusual sizes that no one else is selling. I'm only not convinced to CPU/GPU blocks. I had problems with every single CPU and GPU block I had. Most of them were leaking after longer work under higher load. I guess it was related to the CPU/GPU heat.
As long as my tower can fit one of those radiators I am game for it. Would like to see if is cheaper building one than getting the Corsair water cooling hardline kit. XD
I haven't had an Alphacool watercooling part in ages. They have become quite the force in the enthusiast watercooling world. I know a bunch of people still using their products. Jeff (Stereo55) has several of their AIO's and has successfully modded them to work in certain configurations.
I just picked up a Alphacool NexXxos XT45 Full Copper Radiator 280mm to add to my loop for my 1080Ti along with an EK full cover block.
I do like their full copper construction, and Wizzard at TPU has measured very low liquid pressure drop, but they still don't perform as well as the HW Labs GTX. Granted, we're not talking a lot of difference in temps in the grand scheme of things.
Loading new replies...
Benching Team Leader
Gulper Nozzle Co-Owner
Señor Senior, Senior
Powder Junkie Moderator
