Table of Contents
Today, Alphacool launched four new radiators for the NexXxoS series, the XT45 Dual-Flow 360 mm, UT60 Dual-Flow 360 mm, ST25 92 mm, and the ST25 92 mm Dual. All four feature a full copper pre-chamber, cooling channels, and cooling fins. The XT45 and UT60 Dual-Flow 360 mm radiators are designed around Alphacool’s X-Flow concept and create two separate cooling chambers. This design is marketed for server applications where space is severely limited.
The ST25 92 mm and ST25 92 mm Dual (184 mm) radiators are compact and perfect for cooling the growing trend of mini-PCs and small form factor (SFF) applications. All four products are currently available on the Alphacool website. Prices are listed below in the press release.
Alphacool today presents the NexXxoS XT45/UT60 360mm Full Copper Dual-Flow and the NexXxoS ST25 92mm Full Copper radiators
With the NexXxoS XT45/UT60 Dual-Flow and the NexXxoS ST25 radiators, Alphacool is once again expanding its range of high-performance all-copper radiators.
The NexXxoS XT45/UT60 360mm Dual-Flow radiators have been specially developed for use in servers. A new feature is that the dual-flow radiator based on Alphacool`s X-Flow technology is split in the middle and this consists of two smaller X-Flow radiators. Due to the limited space in servers, the use of multiple radiators is often not possible. With dual-flow radiators from Alphacool, tubing can be routed easily and, depending on the scenario, it is even possible to create two separate water loops.
Due to their extremely flat design, the new Alphacool NexXxoS ST25 92mm Slim radiators offer the ideal foundation for an effective water cooling solution in mini PCs or SSF systems.
Alphacool NexXxoS XT45 Full Copper Dual-Flow 360mm Radiator
Alphacool NexXxoS UT60 Full Copper Dual-Flow 360mm Radiator
Technical data NexXxoS XT45
Dual-FlowNexXxoS UT60
Dual-FlowL x W x H 415 x 125 x 45 mm 415 x 125 x 60 mm Material cooling fins, cooling channels & prechamber copper copper Material outer housing steel steel Fins per Inch 12 12 Threads 12x G1/4“ 12x G1/4“ Fan size 120 mm 120 mm Fan slots 3 one-sided /
6 double-sided3 one-sided /
6 double-sidedMSRP 109,99 € ($129.93) 132,29 € ($156.28)
Alphacool NexXxoS ST25 Full Copper 92mm Radiator
Alphacool NexXxoS ST25 Full Copper 92mm Dual Radiator (184mm)
Technical data NexXxoS ST25 92mm NexXxoS ST25 92mm
Dual (184mm)L x W x H 132 x 92 x 25 mm 225 x 92 x 25 mm Material cooling fins, cooling channels & prechamber copper copper Material outer housing steel steel Fins per Inch 15 15 Threads 2x G1/4“ 2x G1/4“ Fan size 92 mm 92 mm Fan slots 1 one-sided /
2 double-sided2 one-sided /
4 double-sidedMSRP 42,98 € ($50.77) 54,59 € ($64.49)
Recent News
No replies yet
Loading new replies...
