Sorry thread starter, for hijacking your thread, but I don't see a neccesity to create another thread. Hope you can understand.
Fellow seniors, hello, I'm new to overclocking and I'm from Malaysia, and I faced difficulties to OC from 3.5GHz onwards. My rig specs is at below of my signature.
For easier reference, I've attached HWMonitor screenies right after I've run Prime95 "blend" stress set for approximately 10 minutes. I stopped the test, as the temperature hovering around 61celcius, and even hitted 68 celcius.
Additional info on my BIOS setting, I didn't change any setting on my Core Voltage, as it hovers in between on 1.456v - 1.472v, and only bumped up my Bus Speed to 236 MHz mutiplying 14 to get into 3.3GHz, other options such as HT Link, NB Frequency and even RAM settings or timings are set to AUTO.
I would deeply appreciate if anyone here can enlighten me. Thank you very much!
You cant have your RAM on auto because they'll overclock too..
Thank you for your time for replying me this, I really do appreciate, May I know what should be the appropriate core idle temps? is your TIM refers to RAM timings? What should I set in the Bios then? Is it by referring back to my CPU-Z Memory Tab which is 7-7-7-20-27-1T? Sorry for bothering you all, and Merry Christmas!Your core idle temps at 38c look suspiciously high to me. I would suspect either your cooler is not seated properly or your TIM is not applied well.
TIM = Thermal Interface Material. What we sometimes call thermal grease. The paste stuff that goes between the heatsink bottom and the CPU face. If your room temp is not high (I consider normal room temp to be 21-22c or 70-75F) then core temps at idle with a good aftermarket cooler will be high 20s C to low 30s C.
What backy6 is talking about concerning the ram frequency is that if you start out with your ram at it's max rated frquency and you are overclocking with the front side bus (FSB) the ram will speed up along with the CPU and become unstable before you get very far in your overclock. The ram frequency is tuned to the FSB so when the FSB goes up so does the ram. Therefore, we usually start the ram at a lower frequency level to compensate for this.
Merry Christmas to you too!
There is no reason if you set the ram frequency to 1066 in bios that the PC won't boot. That's weird. Make sure the "DRAM Timing" is on Auto.
Yes, 1600 mhz ram would give you more flexibility in overclocking and better performance.
If you live in a hot, tropical climate like Malaysia and your ambient temps are as high as you state then your idle temps make more sense. My ambient temp here in Washington state, USA is 21c and this time of year we have to turn the furnace on to keep it that warm.
When your FSB was increased to 236 it brought your ram to 1259 mhz, still less than it's rated 1333 mhz so at that point the ram is not limiting your overclock or causing instability. But you need to realize that not only is the ram frequency tuned to the FSB but also the HT Link and the CPUNB (or just "NB") frequencies. If either of those gets too high, especially if you don't support the higher frequency by giving those two components more voltage, the system will become unstable. Stock frequency for both HT Link and CPUNB is 2000 mhz. I suspect one or both of those frequencies is causing the instability or maybe you need more CPU voltage.
Do this: Post back with attached pics of CPU-z tabs "CPU", "Memory" and "SPD". Do you known how to directly attach images with the built in forum attachment tool?
Oh, I see what your problem is now from the pics. Your memory timings are too aggressive for the frequency you are running it at. Compare what your current memory frequency and timings are in bios (shown in the CPU-z "Memory" tab) with what the manufacturer recommends (See the "SPD" tab JEDEC columns). Your memory timings are currently 7-7-7-20-27-1T when they should be 9-9-9-25-34 -1T. You need to go into bios and change the DRAM Memory Timing from Auto to Manual and then change the individual timings shown in CPU-z to correspond to what you see in JEDEC #4. Most of the individual timings you see in bios you can leave on Auto. You only need be concerned with the ones that show in CPU-z.
You're getting BSOD ("instability") I think because you're ram timings were inappropriate. The terminology used for ram timings by CPU-z and your bios may differ in some cases. Usually, the first four line items in the CPU-z list of ram timings correspond to what they are in bios, regardless of terminology employed. When in doubt, make a small change and then go back into Windows and check the CPU-z "Memory" tab to see if the change you made in bios is reflected in what you see in the "Memory" tab. If you want more help than that then take a digital camera pic of the relevant bios section and attach it to a post and we'll help you line things up.
Yep, that looks right now.
You can probably raise the bus speed more if you increase the CPU vcore. Right now it shows 1.424 in CPU-z. But before you do that, have you done any core temp and CPU socket temp monitoring yet? High temps can also cause instability. So what you need to do at this point is have HWMonitor open on the desktop while you run a 20 minute Prime95 blend test. Then attach a pic of HWMonitor at the end of the 20 minute stress test so we can look at temps together.
Lower your FSB by 5 ghz and try the 20 minute stress test again. We can raise it again later and add voltage to make stable if the temps allow it but that's what we need to ckeck now.
If I not mistaken, Coretemp seems to shower lower temp of avg 6-7 deg C lower of the actual temp, you can try to monitor your temp through CPUID HWMonitor insteadSo today my new MB came and I just OCed my CPU to stable 3,6ghz but there is a problem..Coretemp shows me the idle temps around the 30°C but software from asus around 37°C and I dont know which should I believe?
https://www.dropbox.com/s/yggnx9we85uyiqa/Untitled.png
